If it is a sta-rite combo unit, then it probably is one of these:
http://www.pentairpool.com/pool-pro/pro ... em-400.htm
However, I don't think it comes in a 2 HP version according to the web site. The the SRCF2022DO2160 combo unit comes with a 1.5 HP Dynamo which is actually has the same performance as the 1 HP Dynamo and neither is a terribly big pump but I think it would work fine with your setup and it should support solar as long as the solar is not installed too high and they don't use too many fittings getting from the pool to the pad. The downside to that combo unit and in fact all combo units is the filter size. It is a little small for your pool size but that just means cleaning it more often. So if that doesn't bother you much, you could stick with what they are proposing.
However, there are a couple of trade offs that you need to consider and there are two ways to design this system.
Option #1
If you go with the combo unit, you will want to keep flow rates low to keep the filter working properly so having long runs of 1.5" plumbing is not a bad thing in this case. Plus combo units are cheaper than buying them separately but the downside is the system will cost more to operate ($$/turnover) plus you will be cleaning the filter more frequently.
Option #2
If you go with a separate pump and filter, you can up size the filter so it can handle more flow rate and if the filter can handle more flow rate, you can up size the pipe (2") to reduce head loss so the pump can actually deliver higher flow rate. In this case, the same 1.5 HP Dynamo will operate close to 20% more efficient than in option #1. Plus you will be cleaning the filter less but again, the downside to this is that the pump and filter will probably cost more than in option #1.
I wanted to give you both options because both will work in my mind, they just have different trade offs. But to give an idea of the difference, I modeled two systems based upon your specs and here is what I come up with:
Option #1 - Combo Unit, 2.3 sq-ft filter, 1.5 HP Dynamo, all 1.5" plumbing, single 1" return eyeball
Option #2 - 4.6 sq-ft filter, 1.5 HP Dynamo, all 2" plumbing, dual 2" return eyeballs (that size pool should have at least two returns)
[tr:2efvwplh][td:2efvwplh]
Summary
[/td:2efvwplh][td:2efvwplh]
[center:2efvwplh]Option #1[/center:2efvwplh]
[center:2efvwplh]Option #2[/center:2efvwplh]
[/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh]
Pump Speed (rpm)
[/td:2efvwplh][td:2efvwplh][center:2efvwplh]3450[/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh]3450[/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh]
Water Flow (gpm)
[/td:2efvwplh][td:2efvwplh][center:2efvwplh]44.8[/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh]61.6[/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh][/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh][/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh]
Suction Head Loss (ft)
[/td:2efvwplh][td:2efvwplh][center:2efvwplh]6.2[/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh]4.0[/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh]
Pad Head Loss (ft)
[/td:2efvwplh][td:2efvwplh][center:2efvwplh]19.4[/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh]19.0[/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh]
Solar Head Loss (ft)
[/td:2efvwplh][td:2efvwplh][center:2efvwplh]NA[/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh]NA[/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh]
Return Head Loss (ft)
[/td:2efvwplh][td:2efvwplh][center:2efvwplh]8.5[/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh]6.0[/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh]
Jet Head Loss (ft)
[/td:2efvwplh][td:2efvwplh][center:2efvwplh]6.2[/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh]3.2[/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh]
Total Head Loss (ft)
[/td:2efvwplh][td:2efvwplh][center:2efvwplh]40.3[/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh]32.2[/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh][/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh][/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh]
Input Power (Watts)
[/td:2efvwplh][td:2efvwplh][center:2efvwplh]1103[/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh]1245[/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh]
Energy Factor (Gallons/Watt-hr)
[/td:2efvwplh][td:2efvwplh][center:2efvwplh]2.43[/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh]2.97[/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh][/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh][/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh]
Suction (in hg.)
[/td:2efvwplh][td:2efvwplh][center:2efvwplh]5.5[/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh]3.6[/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][tr:2efvwplh][td:2efvwplh]
Filter Pressure (psi)
[/td:2efvwplh][td:2efvwplh][center:2efvwplh]11.7[/center:2efvwplh][/td:2efvwplh][td:2efvwplh][center:2efvwplh]9.7[/center:2efvwplh][/td:2efvwplh][/tr:2efvwplh][/table:2efvwplh]
