Ok. If you can't wash it off when it gets dirty or plugged just replace. You should be able to tell if the return water flow isn't like it normally is. That means filter is getting dirty. I forgot you have easy set pool. My bad. ?
When I'm done (according to that 3 part requirement), it says let FC drift back down to normal.... Does that mean we can get back into pool while it's drifting down?? Or do we have to wait until the FC is back between 4-6 before we can get in? Provided the ph and other stuff is still good? Also, at what point to I turn the sws back on for its daily run?
