Hello everyone I am excited to be here. Bought a house 2 years ago with a pool, never had a pool before. Tried to work it out last year then gave up. Started in april trying to find help and tackle this learning curve. Found you guys a few weeks ago. 14k gallon above ground pool vinyl liner. Literally in the middle of an oak hickory forest with limbs overhanging the pool and acorns dropping in it. When I gave up on getting it open last year we put in feeder fish to eat the mosquito larvae and now have about 80 fish from the original 12. Dont worry they are no longer in the pool. Pool had a winter cover which had holes but kept some of 2 seasons of leaves out. So I started with a swamp. Tried pool guy and pool store and finally found you guys before I messed things up too badly (I think). I had added baking soda and lots of chlorine and worked on vacuuming and brushing. Tested with taylor 2005 kit plus fas dpd reagents 10 days ago.
Fc 8.5
PH 7
TA 100
CH 0
CyA 50
I had added some pool conditioner before these readings and had pucks in skimmer as cya was 0 when I started.
I added 51oz borax for pH and started slamming with a 56% cal hypo because it was on sale and my calcium hardness was 0 so I thought it would be an ok choice. I have been as vigilant as I can some days only 2 chlorine additions other days 5 or 6. Last night lost 1.5ppm chlorine overnight and had 1ppm cc this morning. Slamming to 20 ppm.
Put ladder in at start which sounds like was bad idea it wasn't very clean.
Been adding de to the sand filter which I think might be a little undersized and I may need to clean the sand. Psi 14-14.25 after a backwash then after adding 2 cups de and waiting 2 minutes it will not quite reach 15psi. It was going up 1 psi after 3/4 cup de a few days ago i thought. If I backwash, add 1.5-2 cups, plug in aqua bug vacuum in skimmer the vac with zip around for a few minutes then stop and after about half an hour pressure is up to 17 or 18 psi. I need to disconnect vac to see pressure as once vac is plugged into skimmer pressure goes down to around 10.
So my questions
How big is this sand filter?
Is that really small for this forest wonderland pool?
Do I need to clean the filter (flush with hose-I read that article a few times)?
What else can I do to get rid of this cloudiness and closer to the kids in the pool instead of hearing them ask constantly if they can swim yet? I can see about halfway to the bottom.
Sorry for the long post but from lurking on the forum it looked like more info is better.
Pictures of pool before cover taken off, filter, pump, and pool today.
Thank you soooooo much!
Fc 8.5
PH 7
TA 100
CH 0
CyA 50
So my questions
