Hi Blackjack! Welcome to the forums!
Good job reading through Pool School, getting a test kit and posting some results. However, the results you are getting with those strips ( I remember those!) are not what we consider reliable. They may be giving you something close, but in all reality, there are too many variables with the strips. My experience with them is that they are usually way off.
Please read Getting Started:
http://www.troublefreepool.com/content/165-getting-started
Add the following in your signature:
The size of your pool in gallons
If your pool is an AG (above ground) or IG (in ground)
If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
The type of filter you have (sand, DE, cartridge) and, if you know, the brand and model of the filter.
If you know, please tell us the brand and model of the pump, and mention if is it a two speed or variable speed pump.
Date of pool build/install, particularly important if less then a year old.
Other significant accessories or options, such as a spa , SWG, or cleaner
Congratulations! You have taken the first step in learning about how to maintain your pool. You took the correct first step in cleaning your filter and making sure it is working properly. We don't want to assume or do too much until you get your kit and we can get some accurate results posted. I wouldn't be surprised if your CYA is going to be way high. What type of chemicals have you been putting in your pool? If you are using any type of "chlorine" from the pool store ( dichlor, trichlor, powdered shock or algaecide) please stop using immediately!
Hopefully you have read enough to know to use bleach (at least 6.25.%) unscented just plain bleach, to SLAM your pool. Going with your pool size, 25k gallons and a CYA (for now) of 50 targeting a Shock level of 20ppm you should add 4 gallons of 6.25% bleach.You can do this yourself using Pool Math:
http://www.troublefreepool.com/calc.html
I wouldn't do anything else until you get your kit. The next step would be to adjust your PH. But without knowing your current and accurate CYA level we should hold that off for now.
Again, read through pool school, Slowly add in your bleach over your returns, wait for your kit and I'm sure one of our Moderators will be along with some great advice. I hope I didn't overstep my boundaries with the advice I gave, but think it will get you started. Good luck!
