I got my first hot tub up and running about a month ago and the base (no use) chlorine consumption seems really high compared to some of the comments that I am reading here. I have a new 275 gallon covered acrylic tub with continuous circulation and ozone. I am using the dichlor/bleach method. I purged with awwsome before filling the tub, hose off my filter once a week, dose with aqua clarity once a week, and haven’t added anything else to the tub except for a couple tsp of dry acid.
I dose with bleach up to 6-7 ppm and 24 hours later it will be down to <2. If I wait 36 hours, it will be down to zero. This doesn’t seem normal - is it? Should I reduce the duty cycle on the circulation/ozone? Unplug the ozone all together?
The water stays clear, I’m not getting any foam, the filter seems to stay clean and everything seems stable. It just seems like it’s consuming a lot of chlorine.
My other water parameters are:
CC <0.5
Ph 7.7
TA 60
CH 110
CYA 30
CC <0.5
Ph 7.7
TA 60
CH 110
CYA 30
