I am new to this forum and have enjoyed reading a number of threads about air bubbles in return jets. But, thought I would contribute my situation and see whether there is need for concern. After many years of single speed pump usage, I made the transition to the Pentair Intelliflo2 VSF. The installation was done by a large, national chain store and for the most part, I am pleased with the level of service and the redesigned plumbing. The installation included the pump and four Pentair diverter valves. (wish I would have specified Jandy..) I am getting accustomed to the broad range of operating parameters but, regardless of operating speed, I get tiny air bubbles coming from the pool/spa returns.
The bubbles are seen at various speeds I have tested: 100%, 70%, 50% and 35%. All indications point to a suction side leak. The installer came back and check a number of things but in the end said it probably is not a problem and to keep an eye on it. My biggest concern is the gurgling and chattering I hear in the pump. Is this normal for a VSF? Or, is it cavitation? The installers used a clear pipe glue which I had never seen before. After installation and startup, I found a few wads of glue residue in the pump basket and in the pool. Could the impeller be clogged ?
Other comments: I tried running the pump at full speed; then, turning it off to detect spurts of water from suction side of plumbing. Nothing there.
I also notice quite a bit of gurgling on the return fitting coming out of my ancient heater. The inline chlorinator has a one way check valve that is quite old and wondering whether it could be the source of the problem.
Like other posts I've read, it is not unusual to see a fair amount of air in the pump basket; something I never experienced with a single speed. When the pump starts, it goes into priming mode and fills the basket. During that period (and a short period afterward) I see a very large amount of air come from the returns. Once the pump settles into normal mode (70% and then 50% later in the day), that's when i see continuous, tiny bubbles.
Thanks for reading. Hope to see some interesting responses and start learning about more ways to ENJOY ~!
