Had the pool for 2 summers now. Last fall I saw problem after problem with my pool, figured I wasn’t filtering enough, or keeping up on chemicals. Well I winterized and then put her to bed because it was just getting too cold (clear, mostly). Well I opened her up recently (been a busy spring and hard plumbed the filter this year) and water was greener than previous spring. I added liquid chlorine and what used to be able to clear it up in a night only turned it a teal green now.
Well I got on the internet and found this website, started reading- holy molly did I not know what I was doing before! Well I ordered a test kit that I got Friday.
Here is my situation:
CYN - >100 ppm, I think. I’m having trouble figuring out when the black dot just disappears, if I backlight it (did the test at dusk one time) I got 80 ppm. Either way, it’s high. I’m wasting to just drawing air into skimmer and refilling to top of skimmer (done once refilling for the second time).
Running filter 24/7 at the moment, with auto vac running around (let’s me bring water down further at the skimmer).
Plan to SLAM following that.
Questions:
-Haven’t added any other chemicals (since I’m just going to waste them) should I be trying to regulate?
-Am I missing anything with measuring CYA?
-Is my plan sounding right?
Questions:
