Morning,
Here are the Taylor K2006 Results below, brief what I did below that.
FC: 2.8
CC: 0.0 - This was .2 on Monday but I added some Liquid to shock it up again
CYA: <30 - Could still see the dot, was cloudy but still visible
PH: 7.6
ALK: 110-120 - Was in between at 11 drops but was blatant at 12 drops
CA: 100
SALT: 2900
Pool Setup:
30ft? Above Ground Pool (Tape measure was a little over 30ft)
Hayward Power-Flo LX Pump
Hayward Sand Filter
Hayward AquaTrol SWG w/ T5 cell
I opened the pool 2 weeks ago.
Purchased this house late last year, pool was already covered and winterized per the owner. Cleaned as much of the fallen debris that I could, but I couldn't see anything.
(4) 1Lb packs of Burnout premixed
After 2 hours (1) full bottle of Bioguard Banish
Pump was left running for 48 hours (Backwash twice a day)
After this I was able to see blue cloudy water
Went through a 1 week Shock keeping levels at 10ppm+ and wasn't getting much progress. Ended up Vacuuming for 3 days to waste a good 5,000 Gal of water+. Kept shock levels and water cleared up.
Added (10) 40lb bags of Pure Salt to get the SWG generating.
At this point I am losing FC as my CYA level is low, however I don't want to go adding things without referencing here. What are my next steps?
Unfortunately I did not grab any black swamp pics...
FC: 2.8
PH: 7.6
CA: 100
SALT: 2900
Pool Setup:
Hayward Sand Filter
