- Jun 22, 2014
- 52,033
- Fiberglass
- CircuPool RJ-45 Plus
I can tell you .....don't have an idea on what my next step should be?
Passing all 3 SLAM criteria (OCLT, 0.5 or less CC, and clear water), it's time to enjoy the fruits of your labor. Let the FC fall to the normal range as noted on the FC/CYA Levels then turn on your SWG so it can maintain that idea range value. Once the FC is back to normal, you can test the pH and/or any other chemicals you need.
