Hi,
I am new to this forum and just got a house with a pool (15x30). The pool guy who opened it put some chlorine and the previous owner told me to put some oxy-out to shock it. The water seems to get a little bit cleaner after being opened but it seems to be cloudy. I cannot see the bottom of the pool. I went to a local pool store and have my water tested. Below are the readings.
Free Chlorine: 0.4 ppm
Total Chlorine: 5.96 ppm
Combined Chlorine: 5.56ppm
Adjusted PH: 8.3
Stabilizer: 13ppm
Calcium Hardness: 108 ppm
Alkalinity: 74 ppm
The guy from the pool store told me that PH was high so i have to lower it using PH minus. Put some based on instructions and have to wait for 4 hours.
Then have it tested again to see if the PH has lowered. Shock it again with oxy-out once the PH goes to the normal level.
Is this the right approach for the reading that I have? Totally zero knowledge in maintaining a pool. Please help.
Adjusted PH: 8.3
Stabilizer: 13ppm
Alkalinity: 74 ppm
