So here is my update with new signature too!
My TF Pro Salt arrived 3/6 and tested FC=0, CC=0, CYA=0, TA=300, pH=8.2, CH=50, Salt 1800 (compare to reading on the SWG which was 2300).
3/6 added .33 gal muriatic acid and 1 40 bag salt
3/7 added 2 lb CYA in dangled old sock, pH was 7.8 and clorine block test was est at .5. Added 2 more cups MA
3/9 comparator block est pH=8.2 and CL=1, CYA 50, FC test=1.75 and CC=.5, added remainder of first gallon of MA
3/11 pH 8.2, TC=3, TA=240, added 1/2 gal MA and 2 lbs CYA
3/13 pH 8.2 and TC=5, so added 1/2 gal MA at 6:30 pm. Tested at 8:45 PM and pH was now 7.2
3/14 pH 7.2, CL=5, TA 180, CYA 80, FC=8, CC=0, CH=25, Salt=2400(2900 on panel). Added 25 lbs Calcium Hardness Increaser
3/16 pH at least 8.2 (very dark red), FC=12.5, CC=0, TA=190, CH=300, Salt 2600 (3200 on panel), CYA=80. Added .33 gal MA at 4:40 PM, retested pH at 7:00 PM was 7.5
Water temp tested around 65 degrees.
What do you guys see in these numbers? If this post is a horrible effort then please advise the format that I should use to seek oversight/guidance.
Thanks again!
