Hey All!
Just bought a house and have inherited a new pool. Just put in a new liner and opened in May. Previous owner was a frequent visitor to the local pool store and apparently purchased a lot of chemicals from them - the pool store seems to think they have another fish on the line with me.
Luckily for me - I have been reading up on this forum a lot and have found a lot of great information.
So here it goes - I have gone twice to have the water tested at the local store - I am looking into purchasing my own test kit(recommendations welcome - leaning toward the TF-100).
New Changes
Changed liner 5.6.21 - started fill and pool officially opened 5.14.21 by pool guy. Only thing was added to the water was 600 pounds of pool salt. Salinity shows in line on my RJ60+ which requires 3-4000 ppm of salt.
Pool Store Recommendations
5.19.21 Recommendations - 25 lbs of calcium hardness and 3 gallons of shock or super chlorinate(SWG). What I did - Super chlorinate for 6 hours.
5.29.21 Recommendations - 25 lbs of calcium hardness and 3 gallons of shock. What I did - Nothing as of yet - looking for advice before putting in any chemicals!
My concern is that the SWG at 100 percent can't increase chlorine enough - did I make a mistake, was I supposed to shock the pool then do a chlorine loss test and then adjust the SWG after?
Regarding the recommendations from my pool store - they didn't mention CYA at all - isn't that the most important thing for me to correct first?
Completely lost - hope someone can help, thank you all!
New Changes
Typical daily maintainece is running the RJ60 SWG at 100%/pool pump for 8 hours a day.
Skim the top of the pool for 15 minutes at night and clean skimmer basket.
Run aquabot 1-2 times a week as needed.
Test Name 5.19.21 5.29.21 FC 0.27 ppm 0.28 ppm TC/CC 0.29 ppm/ 0.02 ppm 0.28 ppm/ 0.28ppm pH 7.6 7.7 Hardness 42 ppm 43 ppm Alkalinity (w/ Stabilizer Correction) 52 ppm 50 ppm CYA OVR 5 ppm OVR 5 ppm Copper 0 ppm 0 ppm Iron/Phosphate 0.1 ppm/2598 ppb 0.1 ppm/Not Tested Salt 3678 3867
