New to IntelliCenter ~ Freeze protection questions
colonelkirby
105
DFW - Plano, TX
My filter pump and feature pump circuits have freeze protection on. I have seen both work. Now for the questions.
They both seem to cycle on and off rather than continuous on. With this current freeze coming to NTX should I run both pumps 24x7 rather than risk an issue with both cycling on-off during the freeze? Particularly the feature pump, I'm worried about water freezing in the throats of the descents during an off-cycle.
And for the filter pump, if I run it 24x7 will the freeze protection still cycle between spa and pool mode?
TIA
Todd
Turbo1Ton
1,555
NE Oklahoma
Pentair Intellichlor IC-40
Freeze protection runs anytime the temps are below 37F and freeze protection is turned on for a particular circuit. It should run continuously. My water features pump, and any circuits I have that are associated with it will run consistently as long as freeze protection is active. The only ones that cycle are the pool/spa circuits. It switches between pool and spa every 15 minutes as long as freeze protection is active.
You are saying your features pump cycles on/off?
See the this thread (Featured - Intellicenter Users - Freeze Protection warning) for a warning on freeze protection during a power event or a reboot of the panel.
--Jeff
colonelkirby
105
DFW - Plano, TX
--Jeff
To close this out. User error. ;) Water feature pump is not cycling on and off; its on continously. Filter pump is cycling between spa and pool as expected. Nothing to see here.........
Reactions: Turbo1Ton
Turbo1Ton
1,555
NE Oklahoma
Better to ask about it and have it answered and realize it was user error than not ask and have something damaged. ;)
--Jeff
