WHAT?????? Even after YOU providing the sku and PICTURES?????? gurrrrrrrrrrr adult words!
Kim
even after providing pictures, skus and two distributors in Houston hard to believe I think the tile size was the struggle
Kim
I normally let "Siri" do her thing but this is over the top and approaches being unintelligible......correct and repost pleaseThis are getting better there a point of contention though. I would like an opinion. There doing an all tile spa that sits between a bench 18 inches deep and a tanning shelf. There not tile a few spots opinions? Should I help pay? I feel like it looks awful and common sense.
Thank you that is much easier to read.
Okay here is my input...........I would leave it like it is. The plaster will go where the tile is not and will look great.
If you have them go to the edge it might not look as "finished".
I do not see any problem with the back. Maybe I am not seeing what you mean. (the back is the middle picture right?)
The tile is VERY pretty!
Kim
No one would leave an edge of a pool uncovered unless it's faced with stone or something. However, being "covered" could mean mulch or dirt and grass up to the edge of the coping. If that were done it would look fine and be no issue. The only thing would be that it might be a little bit too much sticking out and may cause grass to die from insufficient roots at the edge. But they could use a concrete saw and remove it. The coping, at 12", seems perfectly normal. How was all of this specified in the contract? Most contracts lack sufficient detail due to lack of attention to the many required details.
