So, my new inground vinyl/concrete pool is up and running. Will post specs into signature soon, but it is 26,000 gal SWG (digital pool pilot) rectangular pool, with Jandy VS pump, cartridge filter and jxi heater. Pool is generally in shade, except for 11-3.
1. The pool co came to set up/explain pump/filter/SWG and because they were missing a part, had to cancel and come back a 2nd time. However....in the process of the 2 visits, they dumped what they thought to be the right amount of salt in my pool 2x. So, SWG salt reading was 5000. I've done minor drain and refill 2x to bring it down to 4800, but I guess I'll have to do about 10x to bring pool to proper levels @ 3500ish. Based on other posts, that seems to be the only way to bring down salt levels, correct?
2. After liner install and pool fill (10 days ago), the pool sat for a week waiting for electrical contractor to hook up equipment. So, the pool became a dirty mess in that week, between tree debris and dirt/sand around edges. Now pump/filter is running, pool has been vacuumed several times by polaris/manually and bottom is clean. Pump filter is running nearly all day. Pool co initially hit and ran a "boost" mode on SWG. Regardless, pool water is still cloudy-ish, especially in deep end where it also has a greenish tint. As such, I'm assuming the water needs to be shocked. Is that what "boost/superboost" mode does on pool pilot? I understand boost is 24hrs and superboost is 72hrs and it increases the purifier percentage to 100% for the period....but what does that really mean? Does that actively increase chlorine in pool (I'm assuming yes to an extent)? Does it also somehow increase salt content (I'm assuming no)? Does hitting boost prematurely wear down the salt cell? Would dropping bleach in pool (at appropriate levels) have same impact?
Thanks!
Thanks!
