Hello all. I have recently purchased a swg system. CG 28669. I have an Intex 15x36 above ground pool. I added the salt as directed in the book(80lbs) hooked everything up, cleaned the filter. While I was sweeping the salt around the pool turned green, probably algae that was on the bottom, then I set the system according to the manual (5hrs on) then set it to boost. 24 hrs later it is still very green. My fc is around 8-10 per strips. Ph shows lowest reading, 6.2, ta reads lowest, 40, calcium hardness near if not 0. PLEASE HELP!
