Hi All, I'm new to the forum after lurking last summer, which was my first as a pool owner. This spring we have had a new vinyl liner installed and added a SWCG and a new robot vac cleaner.
First question, after the new liner was installed, the pool was filled and the installers "balanced" the water. Currently after this I have the following numbers FC 2.5, pH 7.4, TA 140, CH 220, CYA 60. First question, is this TA too high? Do I need to try to correct it? Pool Math seems to suggest the rest is reasonable.
The SWCG was just connected yesterday. my second question is, the salt level says 3100 on the printout they gave me, the SWG screen says 4000 and a test strip reads about 6000. Which number do I believe? What is the best test to use for the salt measurement? If there is an instant salt reading available through the display (and if that is accurate) do I need to also be using another salt testing method?
Third question, the installers told me the SWCG wouldn't generate in the water temp was below 64 degrees, they told my husband 60 degrees, and the manual says 50 degrees. Right now the water is about 55 degrees (we live in New Hampshire and it a slow coming spring this year) and it seems to be generating. I presume the manual is correct on this?
That's all for now. Thanks for your help.
