Hello,
We have just purchased a new spa and I don't have a lot of experience with spas. I do however have an AGP and have had no issues using bleach and MA. I like the simplicity and control of testing and knowing exactly what chemicals are in my pool and being able to adjust that based on usage. My questions / concerns are, this hottub comes with a clearray UV-C technology and an ozonator. I'm told both turn off when the jets are turned on. I have done a little reading about the ozonator and how it is better if they can turn on and off. Apparently, this ozonator is programmable. I have also done some reading about how the ozonator is only a good option if the spa is being frequently used. I have no doubt the spa will be used by 2-4 people daily for at least the first several months. What would be a good suggestion for amount of time we should program the ozonator to run? I think it's only an once a day setting, as in, I cannot have it turn on for an hour and off for an hour etc. It's more like it can turn on and xx:xx and off at xx:xx every day. Also, the dealer told me it is a small ozonator since it has the clearray. I'm honestly just considering disconnecting both for simplicity. Any experience with the clearray? Will this also interact with my chlorine?
For what it's worth, it's a Sundance Optima 880 Series Spa. I will be doing a thorough cleaning with Ahh-Some before using, as this tub was filled in the store.
This is what Sundance advertises with the Clearray:
With the CLEARRAY® Water Management System, even the busiest family can maintain ultra-clean, clear water.
Whenever I hear the words "it's that easy" from a pool store, it makes my brain scream TROUBLE!
Also, I get to pick out a chemical start up kit. I said I'd just take some dichlor. He's trying to talk me into trying Prestine Blue, as "it is just dichlor, but it stays in your tub a lot longer and so you use less chemicals" Suggestions on what to take for the start up chemicals?
As always, thank you for all the help and advise!
Lacey
- Add sanitizer after each use
- Test and balance the pH weekly
- Rinse your filter monthly
- Drain and refill water every 3–6 months
- Replace filters and CLEARRAY® bulb yearly
- Replace the optional CLEARRAY® PRO3TECT™ Automatic Oxidizer every five years
Lacey
