New salt cell needed. Generic? Brand recommendations?
gbrenham
70
Cypress, TX
I have an AquaRite/Hayward system (r 1.59) and need a new cell. Current cell is a Hayward GLX t-15. Bite the bullet and get an OEM for $500 or go generic? If I go generic, who has had good luck with with brand? Where online did you purchase?
look30
32
San Jose/CA
I’m interested too.
YippeeSkippy
16,571
Evans, Georgia
I'm debating the same thing! My cell is 8 years old, never acid washed and just gave up recently. I'm dosing with liquid chlorine at the moment while I debate a new system entirely or a generic cell replacement since my Compupool is now out of business (though worked *great* for me!).
Have you looked at DiscountSaltPool.com ?
Maddie :flower:
chlorinatorpro
In The Industry
Feb 16, 2016
144
CA
Obviously , I'm biased when it comes to which generic cell you should buy but the THREE most important things you should consider are the length of time the company has sold the cell, the warranty of the cell (and whether it's going to be honored), and the plate life of the cell (rated hours).
Many buyers are going to be surprised at the new flavor of the year generic cell on eBay , Green & Clean, that only has a 3000 hour plate life for $289. Explains the 1 year warranty (plus another year at 50% pro-rata). How do I know? They told me. So if you use the warranty when the cell wears out at 15 months, you'll wind up paying $435 for a two year cell.
Chlorinator Pro has been around for six years and warranties it's cell for two full years. Our cells have a plate life that is 2.5x the Green & Clean cell. And we usually answer all questions within 24 hours. We had to increase our price to $324 (and may have to go higher) to account for a 400% increase in the price of Ruthenium over the past six months. Ruthenium is the main precious material that is coated on the titanium plates. This dramatic price rise is the main reason for the price increase of ALL salt cells, generic or OEM. However the only way to keep prices low, which a some generics are doing but not disclosing, is to cut the plate hours. A buyer can't tell the thickness of the coating, especially when the housing is embedded within the mold.
CircuPool is a good brand as well. They communicate with their customers too. A little expensive imo but it was customized from the ground up.
Sorry I had to pull back the curtain a bit but I'm sure many on this board will find it interesting.
Reactions: jblizzle
Newdude
7,804
NY
I replaced my 6.5 year old IC60 this year for $777 no tax or shipping with a preseason sale. I ruined my existing cell acid washing it full strength and overusing boost mode and it still made 6000 hours. I was ignorant and never cared to ask questions because the system worked so good that i HAD to be doing everything correctly. Im expecting much more life from the new cell now that i know better. It pretty much comes down to the age old debate..... bite the bullet and pay now for better quality/lifespan or save now but spend more in the end.
chlorinatorpro
In The Industry
Feb 16, 2016
144
CA
In a perfect world everybody would use their cell the exact same way. But the climate differs from Florida to California and thus the cell use is different. Simply put , rated hours is optimum life if EVERYTHING goes perfectly. Pump time/salt system x duty cycle = hours. If you are running 24/7 at 100% = 8760 hours per year. If you run pump/salt system 12 hours at 50% = 2190 hours per year. It's finding the right balance between running the pump longer or setting the duty cycle higher. The cost of electricity vs. wearing out the cell faster.
But rarely does everything go perfectly.
Hard water, extreme temperatures and humidity, heavy rain, failure to maintain CYA levels, algae blooms, lack of salt. too much salt, improper acid washing are some examples of what can go wrong if pool owners are not paying attention. As many have said on this board the salt cell is a chlorine maintainer. If you lose control of your pool and algae is present, you'll usually have to add liquid chlorine to bring it up to levels where the salt cell can maintain those levels as you eliminate the algae..
Reactions: jblizzle
look30
32
San Jose/CA
Do you have a link to your products ?
jblizzle
43,238
Well some of this raises a question in my mind. As you state, and we have generally said, cells have a certain number of hours that they should be able to generate. What I'm wondering is if it makes a difference in how that time is distributed. Meaning is it better or worse to run at 50% for 12 hours or 100% for 6 hours or does it really make no difference?
Newdude
7,804
NY
The cell doesnt care. It cycles on and off based on the percentage you select. If two choices like the ones you mentioned are equal, then it doesnt matter. It will deplete its guts in approximately 10k hours.
Reactions: LFrankow
jblizzle
43,238
I know that is what we always say and makes sense, but I wanted to hear what the pro "in the know" thinks ;)
mguzzy
When I replaced my cell I check here as well.. The consensus was to replace with the same I had before since the last one worked well for me. I got 9 years out of my first T-Cell-15 so I just got another one. If my controller had been on the fritz I might have been inclined to shop around for different systems, but I stayed with the same controller and just got a new cell. If you keep an eye on the sales and coupons you can get a good deal. I got an OEM Hayward Tcell15 for just under $400 with my various discounts.
goldmanaz
3
Gilbert, AZ
Do tell, because *that* is a great price!
mguzzy
Well I noticed these big ticket items start going on sale toward the end of the pool season, I'm sure because they want to reduce wharehouse inventory for the winter. I watched for sales, free shipping type stuff and promo codes. At first I thought I missed the $100 off offer, so I called them and they were able to still honor it. That sort of stuff!
kcindc
1,299
Fairfax, VA
The cost for a generic (CircuPool) cell t-15 is $449 and the t-9 $349. You can always call to see if they give you a discount.
Their tech support are very friendly, knowledgeable and helpful.
My pool equipment pad had a lightning strike recently. Many things, along with my SWG, was fried. I called CircuPool to see about the process of SWG repairs and it seemed like a huge hassle, mail the unit and cell to them, and wait for a call to see if they could repair it. My insurance ended up paying for a new system and CircuPool (via a phone call) gave me a huge discount on a new replacement system.
MyAZPool
1,915
Arizona
Pentair Intellichlor IC-60
chlorinatorpro
I read your posts and the information that you provided piqued my curiosity.
I perused your website and I see that the Chlorinator Pro is a replacement for the Hayward T-Cell-15. Cool.
In the future, if you develop and market a replacement cell for the Pentair IntelliChlor IC-60, and IF it can integrate with Pentair automation, you will have my full attention.
In my opinion based on everything I have read and from my own personal experiences, the IntelliChlor Cell itself seems to work very well but the Flow/Temp switches and the IntelliChlor EC or Conductivity Sensor inside the cell are junk.
Thanks for sharing.
r.
snmobley
Active member
Dec 10, 2018
39
Birmingham, AL
I had this same question last month and ended up going with a replacement Hayward T15 versus the generic options. I bought off Amazon (I confirmed with Hayward that Amazon was an authorized seller and the three year warranty would be honored if I had an issue) because the price was only $100 or so more than the generics. The previous Hayward cell lasted 9 years (based on the serial number) and I expect this one to last the same or more because I'll take better care of it than the previous owners...hope I'm right!
