- Mar 25, 2019
- 690
- Plaster
- CircuPool RJ-30 Plus
Sounds about right. Would such a test still be valid with 1.0CC? I would think no right?
CCs should have no bearing on production. You would need to deduct your previous night's loss. In a perfect world, you would want to do the test after seeing no OCLT loss. For now, ensure your salt level is in range.Sounds about right. Would such a test still be valid with 1.0CC? I would think no right?
I am not sure what you mean by this.You would need to deduct your previous night's loss
That's because I got it backwards...I am not sure what you mean by this.
That's what I'd do. Will very likely be very short so long as you can maintain SLAM level. Make sure to check a few hours after you get to SLAM level. Keeping at SLAM initially always shortens the SLAM.I’m just gonna SLAM to be sure before I raise the CYA. If I spend 20 bucks on LC for the SLAM to be over in a day or two it’s cheap insurance.
Yes you should, and no it won't. You have to really be in the negative (more than -0.6) for a long period of time for that to happen. You've confirmed the presence of calcium in the cell with the acid test, and a slightly positive CSI will allow scale to form fast. Try to keep your CSI anywhere from zero to -0.3 and that should help a lot.Should I run it slightly negative, and if so will that shorten the life of my plaster?
Your last CH is listed in Poolmath as 425. That's not bad at all. Your TA was listed as 70. That's not horrible either, but with acid treatments in the future it should slowly fall a bit. You can let the TA go as low as 50 and be fine, but no lower than 50. That might also help to slow the rise of pH. PH is always the major player in CSI. Do your best to keep it from exceeding 7.8 for sure.Sounds like I need to add more acid to keep my pH at 7.5 or drain some water to lower my CH.
Go ahead and lower it at once. The pH will rise quickly on it's own. As long as it's 7.2 or above all is good.Do I need to lower the pH to 7.0-7.2 at one time to lower TA or can I do it gradually?
