getting ready to pull the trigger on a new pump.
going from single speed 1.5hp to either Pentair 342001 or Pentair 011018, i've got all 1.5" plumbing and that's never going to change, I wasn't sure if the 011018 running at full blast would potentially damage any of the plumbing or would I only be able to run it at more or less half speed max?
3 settings on the 342001 should be fine for my setup (i hope all that stuff is still in my signature) but everyone loves more options
i'll hold off on the plumbing question until i can get a picture, replacing the diverter valve and the pipe from the old valve to the pump doesn't run straight to the pump, it comes out of the valve and makes a U then goes to the pump, didn't know if that thing served a purpose or can i just cut that out and run a pipe straight from the valve to the pump (typed this out so that i don't forget) i'll get an actual picture later
thanks (learned a lot by lurking here over the past year)
