Hello,
I am trying to rebuild a 1999-ish Jacuzzi spa. It has 2 pumps.
The old J-pump (jet pump) did not come on, so I removed it and took it to a pump repair shop. The inside of the motor was completely corroded to the point that I had to buy a new pump. (I was later able to determine the gate valve positioned directly over the J-pump was leaking which is most likely what caused the corrosion in the old pump.)
I opted to replace it with a more generic 1.5 HP Waterway pump and plumb in new gate valves and new pump unions to match it, instead of purchasing a new Jacuzzi J-pump (6x the cost). After I had all of this installed and turned on power to the spa, the older Jacuzzi recirc pump comes on without any issues. Water is coming out of all the jets. When I go to turn on the jet pump, the seal immediately pops and water starts gushing out of the back of the wet end.
I assumed this must have been a defective seal, pump, wet end, whatever and I was able to RMA it for a replacement.
The second pump did the exact same thing. Seal immediately blown on start-up.
Instead of trying to RMA it a second time, I elected to purchase a new wet end and install it myself, potentially ruling out the possibility that someone at the factory is not installing the wet ends correctly.
The exact same failure a third time.
At this point, I am at a total loss for what is causing this problem. There has to be something I am doing incorrectly! I have absolutely no idea what would cause these brand new pumps to fail within seconds of being turned on.
Does anyone have any idea what might be causing this?
