Hi All, Firstly - Happy Holidays.
I have questions about our pool that we just finished. We had a 5mx3m AG pool built and included a Waterfall "feature". My problem is that the waterfall literally has a trickle of water coming out of it. I will try not to make this a long post, but let me explain the setup.
The pool has no skimmer, so the only "suction" from the pool to the pump is either the drain in the bottom or the connection for the vacuum. When running "normally", the water goes from the drain into the pump (1HP), then to the filter (Sand) then from the filter the tube (2") coming out splits into two, one that goes back to the return jets (x4 - also 2" tubing) and one that goes to the Waterfall (1" I think). Each "Exit" tube has a valve that can be adjusted/closed. The reason for the reduction was in order to put a "smart" faucet controller, to be able to control the waterfall from my Home Automation setup (currently removed and replaced with a flexible tube).
When running the pump with the jets and the waterfall, the waterfall literally has a trickle of water. If you close the jets, then the waterfall does have more "power", but 1) still doesn't flow evenly, and 2) my pool guy (not the one who built it, he has disappeared!) tells me it will be too much stress for the pump to run only the waterfall.
Any help/advice is greatly appreciated! I was thinking maybe another pump just for the waterfall line?
Cheers,
MM
Cheers,
MM
