Hey All,
I'm about to do a new pool construction in Houston, TX in the floodplain. Dimensions are roughly 30'x15' w/ a 6' tanning ledge (3 bubblers), depth is still to be decided but a v shape (shallow->deep->shallow) somewhere in the range of 4'-5.5', so I think it's 12k-16k gallons. I'm going to go with a SWG based on all the feedback in the forum .
I'd like to get y'alls advice on pump selection and how having a raised equipment pad will affect things. We're in the floodplain and our neighborhood does flood, our street a little less so than others, regardless, the PB says we need to put the equipment on a 3' high pad. I'm not opposed since our side yard does gather water 2"-6" pretty easily and much more in the frequent and heavy Houston rains . Does the raised equipment have a dramatic effect on the pump HP needed, or anything else?
Next question is regarding a VS pump versus a 2 or 1 speed. With a pool this size, I'm wondering if I could get away with a 1 speed, even though I also have a SWG and 3 bubblers. I know a VS would give me the most flexibility, but I'm interested in the cost vs. value, and what y'all think it's worth.
Last question is about automation. Once you find out what works for your pool, can you pretty much set a schedule for a repeatable process (pump runtime, SWG settings, etc) or does it always vary so much that being able to control via phone is worth it? Can the SWG be controlled remotely? Is this something that can be added fairly easily in the future?
Any and all thoughts are much appreciated!
