Hey everyone,
Been reading around the site for a few days and hoping to get some help as we are in the planning stages of adding a pool to our new house. We met with builder today and electrician just waiting on some final pricing. Previously had a 27' above ground pool that I had a great process working using an inline puck chlorinator, pool perfect, and non chlorine shock, always had crystal clear water, good PH, FC and never any algae outbreaks in a pool that was in full sun 80% of the day with solar cover.
Our new house the pool will be in Full sun all day as it will sit facing south and after looking at chlorine prices I began looking at other options and need some advice. The new pool is going to be a 24ft x 54" pool, planning to go all resin as we are in open farm country and get 30+ mph winds often. The pool store we are looking to purchase from is pushing a PermaSalt system and friend has the Power Ionizer system both seem like the FROG system that was attached to previous pool that requires their overpriced chemicals to keep and maintain along with not being safe for everyone. I'm now looking at SWG's as the wife is not a fan of the chlorine smell (partly why hot tub has UV and Ozone systems) and would like some advice as I want to set this up from the get go and not change later as we are planning the build in the spring since it's Ohio and propane heat costs would kill me opening for 2 weeks then draining and closing. According to the builder it should be about 13K gallons of water, based on reading posts it seems the CircuPool is the best option for SWG, I'm very tech focused and have gone down rabbit holes of wifi timers for pumps etc but based on everything I'm finding the best options for setup would be...
Cartridge Filter (had previous issues with sand filter and after back surgery not supposed to lift over 60lbs anymore)
Variable speed or 2 speed pump that can be run on low 24/7 pump
CircuPool RJ30+ (supports up to 40k gallons which is 3x pool size)
*Can a bypass line be plumbed in for when needing to skip the SWG for maintenance, opening etc?
Planning to hardpipe everything in and add unions like I did on previous system so when winter comes I can easily take things apart to store in basement for winter
Is there anything I'm missing here or you would add to make a relatively maintenance free pool? My previous pool required 3 checks per week and wife was able to keep up while I was away for work trips so I'd rather stay away from liquid chlorine as much as possible except the occasional need after having friends/family over, normally it will just be the 2 of us using the pool and 80% of the time she's going to float on a raft!
Appreciate all the advice and help, was not looking to put in a pool but after some prodding to skip a beach vacation next year to do the pool and have more relaxation by my own pool she wore me down!
