Hi there Ash
Welcome to TFP
You're getting an Above Ground Pool, right?
We've got some basics for you-
Pool Care Basics
We are a chlorine based pool group. Please, if you can, return both the PoolRx (copper! eeegads!) and the solar ionizer. Both products are useless for you.
Did you consider a salt water chlorine generator (SWG)?? Which about 99% of owners would never do without. Alternatively you can use liquid chlorine (Walmart, Ocean State, Menards...etc sells in 10-12% strength.
What you need MOST of all is a GOOD reliable test kit. We do NOT trust pool store testing- you can take 3 water samples to 3 unrelated pool stores and get 3 varied results + bad advice so you''ll buy more products. See approved list and online sources under the basics listing.
All you need to start your pool up is: Liquid chlorine, Stabilizers (found at Walmart, Amazon, Lowes..) and possible Muriatic Acid.
And you need to get set up on PoolMath, the app, which helps with testing documentation and sharing, and helps you with quantity of chemical to add.
Hello Our pool was installed and filled with water on Tuesday 6/6 and I was wondering what chemicals I should buy to put in the water. The pump has been off because I need to get 2 more bags of sand for the filter. I do have a TF100 test kit. This is new to me so I'm not sure what I should be...
www.troublefreepool.com
Please holler back with questions- we're happy to help.
Maddie
