Hi, I'm a brand new pool owner, first post. My pool has had water in it for a month and I'm just now getting to the point of learning about my pool. The startup was smooth and my pool looks great and I'm testing it weekly at my local supply store and treating it appropriately. My pool builder suggested I continue to run the pool 24/7 but that has some downsides. The pump equipment is behind the master bedroom wall so we hear the pump at night and I just don't think its worth the money to run it 24/7 at any significant RPM. He suggested setting it up to run at a low speed overnight 1200, medium speed in the morning and evening 1800, and higher speed in the hot of the day 2400 (Houston, TX). For the life of me, however, I can't figure out how to schedule different RPM's to run without having any free relayed circuits. I have an EasyTouch PL4 panel and with no free relayed circuits. The circuits in use are Pool, Spa, Blower, Waterfall, and Lights. I can add Aux circuits, but those won't actually activate on the schedules. The only circuits that will show as schedule running are the 5 existing circuits.
In settings, I assigned pump 1 to aux 4 with a speed of 1200, aux 5 with a speed of 2400, and i set the standard POOL circuit to 1800 in hopes of making this all work, but it doesn't. The only schedule that actually turn on and off on schedule is the POOL. I can manually run the Aux4 and Aux5, but they won't run the following day. If i had a PL8, I would have extra relays where I could use the default Pool High and Pool Low circuits. Without these, I'm just stumped.
Am I just being dumb in trying to figure out the settings/schedules/circuits? Its a bit convoluted, but after an hour standing at the panel, I think I understand the mechanics. Maybe not.
Thank you for your help.
Houston
16000 gallons
Chlorine Tabs for supplemental Chlorine (2 tabs lasts about a week)
Currently using Liquid Chlorine as a new pool before switching to powder (pool supply company suggestion)
750 gallon hot tub
EasyTouch PL4
Intelliflow VSF
Houston
16000 gallons
750 gallon hot tub
EasyTouch PL4
Intelliflow VSF
