New pool owner trying to understand test strip reading
Who can provide me with the correct gallons for my pool? Here is the diagram. PB says it’s 22,800. But pool math is not adding up when I added chemicals. Thanks.
As I said, use 25K.
I get 23K not including the shelf. Start with the 25K I suggested and use chemicals to adjust volume from there.
LengthWidth
FeetInchesFeetInchesLengthWidthDepthCubic InchesGallons
Top Volume
37​
0​
18​
0​
444​
216​
39​
3,740,256.0016,191.58
4 corners
48​
48​
36​
-165888​
(718.13)
Slope Sides
168​
48​
56​
327936​
1,419.64
Ramp
14​
0​
10​
168​
120​
56​
564480​
2,443.64
Deep Sides
4​
4​
48​
48​
56​
129024​
558.55
Center Mass
10​
6​
120​
72​
56​
483840​
2,094.55
End Ramp
10​
4​
120​
48​
56​
239211.5​
1,035.55
Corners
-80​
22,945.37
As I said, use 25K.
LengthWidth
Top Volume
37​
0​
18​
0​
444​
216​
39​
4 corners
48​
48​
36​
-165888​
(718.13)
Slope Sides
168​
48​
56​
327936​
1,419.64
Ramp
14​
0​
10​
168​
120​
56​
564480​
2,443.64
Deep Sides
4​
4​
48​
48​
56​
129024​
558.55
Center Mass
10​
6​
120​
72​
56​
483840​
2,094.55
End Ramp
10​
4​
120​
48​
56​
239211.5​
1,035.55
Corners
-80​
22,945.37
Oh okay. So the PB wasn’t too far off. He probably didn’t take into account the shelf when providing me with the gallons for the pool. I thought maybe with the actually diagram we could figure out the exact amount. Thanks again
The plans are wall height so the PB is probably right and when we subtract 6 inches for water height (about 2500 gallons) its a hair over 20K.
Pas, how is it behaving when you add stuff ? Have you seen said discrepancy with everything or only bleach ? I trust salt / cya / ch / baking soda (etc) alot more because they don't go in weaker than claimed like bleach might.
Good catch. Updated. Still without the shelf..
LengthWidth
Top Volume
37​
0​
18​
0​
444​
216​
34​
3,260,736.0014,115.74
4 corners
48​
48​
34​
-156672​
(678.23)
Slope Sides
168​
48​
56​
327936​
1,419.64
Ramp
14​
0​
10​
168​
120​
56​
564480​
2,443.64
Deep Sides
4​
4​
48​
48​
56​
129024​
558.55
Center Mass
10​
6​
120​
72​
56​
483840​
2,094.55
End Ramp
10​
4​
120​
48​
56​
239211.5​
1,035.55
Corners
-80​
20,909.42
I’m spot on 3600 on salt. And I was going off the 22800 number.
As for the one time that tried muriatic acid the amount was supposed to lower pH .4 but only lowered it .2. But it’s back up to 8 last time I checked (but that test is an eye test so not really sure of exact number.
So you are saying put pool math back to 22800?
Added LC, muriatic acid and stabilizer last night.
I will test a little later today to see what effects the acid and LC had. I know stabilizer will not really show for a couple days.
Appreciate all the help from you guys and this forum making me feel more comfortable taking care of this pool on my own.
