Hi,
We just set up our first pool, its a 16x3'6 intex inflatable pool with a krystal clear filter. Our only water source is our pond, we have a huge system set up in our basement completed w/ a chlorinator and two huge water tanks and 3 wall filters. I'm sure there's more but unless you need complete details I don't know off hand, that's not my department :?
It took us a while to get it filled up but now it is all said and done, and the water is not pretty looking.. Its a yellowish color and I'm not liking it.
The book that comes w/ the pool isn't good for details on what exactly needs to be done. I have bought some test strips and shock and chlorine sanitizing tablets. I added 1lb of the shock to the pool and added (5) 1" chlorine tablets by HTH.
I just finished doing a test strip and got the following readings
FC: 3/6
PH: 7.5 - 7.8 (kinda right in the middle, too hard to distinguish which one)
TA: 40
TH: 200
CYA: 30-50
I'm not exactly sure what all I can do or what I can add that won't throw the readings off too much to turn the water clear or at least a little more clear. I'm new to this and don't understand what exactly all the chemicals do and when its safe enough to be swim ready.
TIA!
~Auty
FC: 3/6
TA: 40
TH: 200
CYA: 30-50
TIA!
~Auty
