- Oct 31, 2021
- 36
- Plaster
- Jandy Aquapure 1400
After maintaining my pool a few weeks and had a couple of questions. Hope someone can help.
1. I lowered my PH from 8.2 to 7.6 about 10 days using MA but it increased to 8.2 again today. I am trying to understand why. First I guess it is because the TA is at 150 which is high. To lower the TA, Pool Math suggests to lower the PH to 7.0-7.2 and aerate to increase PH. as well as in this link Do I follow that exactly? Because lowering PH from 8.2 to 7.2 would require quite 72 oz of MA, can I do that in one time or split into 3 * 24 Oz and add every few hours?
2. My pool does have a water fall feature which runs with the pump, will this keep increase the PH all the time?
3. Will the SWG stop producing chorine when temperature is lower than 60 degF?
4. I have two skimmers, the one located farther has much less suction than the one closer to the pump, how to adjust it or do I need to?
Thank you very much
Thank you very much
