We recently moved to GA (Atlanta area) into a house that has an inground heated pool. It is a small 10000gal pool with a heat pump for heating and salt water chlorinator. I recently had the main filter pump upgraded to a variable speed pump. The pool also has a booster pump for a Polaris 3900 sport cleaner. There is also an automatic cover on the pool. I am trying to figure out what I need to do or how I should operator the pool in the winter months in GA.
- Should I close the pull for winter?
- How late/early in the year should I expect to be able to use the pool?
- Should I be heating the pool all the time or only a couple days before we plan to use it?
- I assume I should keep the cover closed as much as possible to keep it cleaner and keep the heat in?
- What sort of pump schedule should I be using during the winter? During the summer, I was running the pump at 50% for 18 hours a day. FYI, the pump does have a freeze protection feature.
- I assume I don't need to worry about the running the pool cleaner when the cover is closed, only when its open?
Sorry for the all the questions, but I appreciate any info that anyone is willing to share.
