New Pool Owner Needs HELP!!
efales
1
Hi Everyone!
I just purchased my first home and it has a pool...a GREEN pool! HA! :mrgreen: I have been trying to about 2 weeks to get this pool back to blue. I have put it an entire thing of algeside and 8 bags of shock so far. Nothing is budging. I try to clean the filter twice a day.
Pool - Under ground
Filter - Hayward Star Clear Plus C900
Here's the issue now...I tried to vacuum the pool today to see if I can get more of the algae out. When I put the hose into the skimmer...I don't get any suction. The jets are pushing out water (sometimes stronger than others) but the skimmer isn't sucking.
What are my next steps? Any ideas are greatly appreciated.
Thanks!
Isaac-1
6,711
SW Louisiana
I would suggest starting with reading the pool school link in the upper right, then read some of the advanced material on the SLAM process and how to clear a swamp, we can help with step by step along the way, but it really helps to have a common language as a starting point.
Ike
p_mori7
17
There is probably a diverter valve before the filter. The selector should be placed midway between skimmer & bottom drain.
jblizzle
43,238
:wave: Welcome to TFP!!!
I agree at least read the ABCs article so you understand the terminology. Then you will need one of the recommended test kits (see link in my signature) and then follow the SLAM process. [slam:2gbv26ih][/slam:2gbv26ih]
BTW a 3-way valve selecting between the floor and skimmer would be found on the suction pipes before the pump (which I suppose is technically before the filter). If you do not have valves at the equipment, there could be a float diverter in the skimmer under the basket.
