Hey DB,
Set the expectation of a day or two after filling (could change based on water temp - everyone's threshold below 78 is different), maybe a week in Tampa.
You are right, test the water first to get a baseline, you want to know what the TA, CH, ph levels are. Also test FC for good measure, and water temp. No need to test fill for CYA (but others may differ in that opinion). Plug those numbers into pool math along with the setup (Pool size, Target Values, and the goals section). When you add the target for CYA it will tell you what to target for FC, verify after setting goals.
Then get the FC up to around 5. Keep at 5, for now. Adjust the ph if needed.
Next start adding the salt, half at first. Let mix for a day and retest. This will help confirm your gallons. Then add salt based on the new test value to the target. 24 hours after adding the second batch of salt measure again. If good you are one step closer to using the SWG (water temp is the other).
After a few hours at the FC level retest, top up if needed - like a mini SLAM. An hour after this top off I think you could swim in it. But water temp is going to be a big factor in that.
The first day also start adding the CYA. At the end of the second day, I would, raise the FC target to above 8 because there will now be CYA in the pool. Keep using Chlorine until the water temp is above 55 or 60. Turn on the SWG and enjoy (after the salt has dissolved from the second addition)
Watch how the CYA dissolves (I use the sock method on a pole in front of a return and squeeze every few hours). When fully dissolved wait a day then test. Suggest you add 3/4 of what is needed, again until you confirm the gallons and how the water responds - easier to add more chemicals than to drain water and fill to lower chems.
FYI - Keep testing ph and FC daily until you get the hang of it and understand how your pool responds.
Enjoy your new pool
