New pool owner here with a bunch of questions. The pool is a ~25,000-gallon inground pool. I went to a local pool store and followed their recommendations about two weeks ago. I think misunderstood their directions and added too many trichlor tablets (or maybe they gave me bad advice). Either way, I learned my lesson and want to do things the TFP way.
Here are my most recent test results using the TF-Pro test kit.
CYA - 120
FC - 11.5
CC - 0
PH - 6.8
TA - 80
CH - 250
I know the CYA is high so I guess I need to drain the pool? What is the easiest way to go about doing this? How much should I drain?
Also I know that my pH is low. Should I address this now or wait until after I drain the pool and fix the CYA problem?
Is the pool safe to swim in or should I stay out of it until I get everything into the correct ranges?
Thanks
CYA - 120
FC - 11.5
CC - 0
PH - 6.8
TA - 80
CH - 250
Thanks
