Hi guys! Just wanted to drop a note saying hi. New15x30 10,600 gallon oval above ground pool with cartridge filter 2hp pump and vision pro chlorination. Looking for the easiest less chemical way to maintain a healthy pool. Glad to be here.
Yes to the mineral question.That’s why I’m here to learn more and be able to share. I assume I can replace the mineral cartridge on that vision pro and put the cap back on it and leave it at that. Can I also remove the chlorine cartridge and just drop tabs straight in the chlorine side?
I appreciate your thoughts. Thanks!You can remove the mineral cartridge and put back on the cap. Glad you have it. Most installers throw it away.
The trichlor side only takes their cartridges. If you read the link I posted, we suggest you not use trichlor for daily chlorination purposes. It will lead you to poor results.
