hi guys,
I recently bought a home with a pool, first time ever having a pool (las vegas area). There is a pool company from previous owner that has been servicing the pool for the last 2 months (since I bought the place).
I am here because I want to take care of the pool on my own, so I have reading this forum for a while now, bought a taylor k2006 test kit and today I tried to test the water for the first time.
I have never seen the pool guy test the water, I have a floating thing with chlorine pucks and according to the pool guy, the water was changed by the previous owner before I took possession and the pool has been treated again algae for the next 6 months. That's what the guy says.
I am attaching a picture of the pool and the floating thing.
So, here is the situation with the water if I tested it correctly (I watched a bunch of videos on how to use the test and followed the instructions inside the box).
Free chlorine 12 ppm, no combine chlorine
PH 7.8
TA 140
CYA over 100, it took not much water for the black dot to disappear to the point that the sample did not even reach the 100 mark.
Calcium Hardness: 390 (39 drops with 25 ml sample)
That's the situation.
As far as I understand, pucks are not the best source for chlorine, the free chlorine value is pretty high (ideal 4 to 6), ph slightly high (ideal 7.4 to 7.6).
CYA is high and not a good thing... CH might be ok although toward the high side of the range.
Is that correct?
Any suggestions in what to do from here are much appreciated. Thanks a lot
PS: pump stays on 8 hours a day right now.
PH 7.8
TA 140
Is that correct?
