New Pool Owner here. Just a little history... I recently bought a house in November 2016, so I had the pool for about 6 months. When I moved in, I knew absolutely zero about pools, therefore I used the method that the previous owner used to maintain the pool.
The previous owner, shocked it on a regular basis with Leslie's Chlor Brite and used their Ph up and other alkalinity products. Therefore I used the same method before finding about BBB last week.
I just opened the pool on Saturday 5/20, the pool has a tinge of green. I went to Leslie's got my water tested and my FC was 0, Ph 7.2. I had 2 lbs of Chlor brite shock left so I used it to shock the pool and added 2 gallons 128 fl oz of 10% bleach to the pool. I checked my Ph on Sunday and it was 7 ppm. It rained Monday night and today I went to buy a better test kit, I've bought a Taylor Technologies K-5820 - OTO Deluxe Test Kit from Lelslies (got the CYA tester separately) and I got my water tested again due to the rain. To my surprise, once again my FC went down to 0, but my CYA is at 95-100. The pool clerk told me that the Chlor brite was adding extra CYA to the pool and that I need to stop using it. He recommended to switch to Fresh and Clear with he states does not have CYA. When I asked about just using bleach he said you can but bleach will add extra CYA as well. I read up on this, and bleach doesn't add CYA.
FC 0
TC 0
Ph 7.4
TA 150
CH 210
CYA 100
With these values, I've added the recommended acid to get my TA to 100. I plan on Shocking/SLAMMING the pool tonight with 5-6 gallon of 10% bleach.
I want to stick to BBB, but...
Any help would be greatly appreciated. Thanks in advance.
FC 0
TC 0
Ph 7.4
TA 150
CH 210
CYA 100
- What can I do to maintain my chlorine levels on a consistent basis? Do I need to add a gallon of bleach to the pool every night (I've read some people do that).
- I have a tower which I put the 3" chlorine tablets in, I was under the impression that it should keep the chlorine levels high enough, but that's not the case. Also the pool clerk told me I should get a chlorine floater to put additional 3" chlorine tablets to help supplement since my tower is not providing enough chlorine for the high CYA. Is that a good option? I've also read that people put the Chlorine tablets in the skimmer basket to avoid a floater? Is that also another option? Or should I completely stop using the 3" chlorine tablet because I read that it also increases the CYA.
- I've been reading with my high CYA level, I may have to partially drain the pool to get the levels down. Do I need to do that? If I set my pump to waste, would that be an efficient way to drain it?
