Hi all,
First time pool owner here. I need some advice to see if I doing the maintenance correctly.
About 25000 Gallon Vinyl Pool, Hayward Sand Filter, 1 level pool pump, Heat Pump, Polaris - VRXIQ+ cleaner, K-2006C test kit. I believe the pool was installed back in 2006
Pool filter runs 12 hours a day
My current reading
Alkalinity: 70
PH: 7.5
Calcium: 140
CYA: 50
Free Chlorine: 8
My weekly maintenance procedure: Dump the robot in the pool and let it run for 2 hours. While the robot is running, I will clean out the skimmer basket, brush the sides, and use the net to catch anything flooding the surface. I will do a backwash if the pressure goes up.
After cleaning, I will test for Alkalinity, PH, Calcium, CYA, and Free Chlorine.
I will add Alkalinity, PH, CYA about every 2 weeks.
I will add a bottle of super shock every 3-4 days. (I estimated a bottle of shock will raise about 4 of Free Chlorine)
I don’t add any other chemicals to the pool.
Pool water looks as clean as when the pool guy who first opened the pool for me.
I am following this recommended level What Are My Ideal Pool Levels? and Chlorine / CYA Chart
My questions are
Thanks
My current reading
Alkalinity: 70
PH: 7.5
Calcium: 140
CYA: 50
Free Chlorine: 8
My questions are
- Is my procedure correct? Is there anything I should and shouldn’t do?
- Currently I am using MEGA Pool & SPA Chemicals Super Shock, is this good? I am still bit confused between shock and liquid chlorine, my local pool store tells me shock and liquid chlorine are the same.
- My local pool store told me to disregard Calcium because I have heat pump, not sure if this is true.
- I have 2inch 75ft backwash hose, I need to add another 2-3ft to reach to the street. Any way to extend the backwash hose. I think the backwash waters are killing my lawn grass.
- I have some yellow stain on some edges of the pool. Is it possible to remove them? Maintenance guy told me because the previous owner hasn’t opened the pool for few years, which caused the stain.
- I did a bad job sanding my patio, sands keep on getting into the pool. I don't want to redo the patio at the moment, anyway to keep the sand from getting to the pool or just picking sands from walking?
Thanks
