Hi all, just moved into a new house with a pool. Had a pro open it up to start and the pump needed replacing, which was expected. What we didn't expect was the pool heater, which is apparently just 2 years old to not work.
It's a Jandy JXI 260N gas heater. The thing is, when you turn it on it fires up and the panel is lit, but it just will not respond to any button presses. It stays on the settings it is showing and after a minute or two, it stops firing as well (panel still on, but no heating sound). The panel shows pool temp at 73, desired at 86, and it is set to "Spa" heater but no buttons work so it's not like I can change it to pool heater.
I had someone come out to look at it and they called Jandy who had us try some different button holding combinations to reset things but that did not work. I'm the end they recommended changing the power control board or something like that. That part was apparently going to cost around $800 (Canadian) plus install. And no one could guarantee that this was even the issue. It just might help.
Our pool guy (not the gas fitter who called Jandy) says Jandy is Crud, it probably won't work even if we get that part, and that were better off just getting a new non-Jandy heater.
I do not know who to believe. It does seem like an electronic or electrical issue. Has anyone experienced something like this with this line of heater? I'm not handy, but I'm comfortable with electronics. It just feels like this thing is not too far away from working and, at most, replacing the board should do it, but I'd love to have more confidence in something like that before dropping the $. Thanks in advance.
