New pool need some help with chemicals
At this point function on the assumption that you are at 40 and test in a week for cya.
Your target cl is between 3 and 7, you are a little high at 10 but still swimable given the shock level of 16.
Ph is good at 7.6
TA is a little high, I wouldn't worry about it until everything settles in and you see how much ph drift you have.
All in all it looks like time for a pool party to me, good job!
I see your holding FC that's a good thing !
I would just let it drift down to your maintaince level's. I would target 7 and don't let it fall below 3. That gives you wiggle room so you don't fall below your min.
When your TF 100 comes post up a full set of test results if you could. ?
New results with my new TF 100! (I love this thing)
FC 7.5
CC .5
CYA 32
PH 7.2
TA 80
CH 125
I'm going to add 8 ounces of stabilizer to get the cya exact and let the rest simmer. Thanks again for all the help!!!
21' X 4' AGP 10400 GAL
1.5 hp pump
Sand filter
no SWG
TFPC method
Hang tight on the cya. It takes a week for it to show all the way up on the test. Assume 40, test after a full 7 days and adjust accordingly.
Sent from my iPad using Tapatalk
