Hi All,
We had a pool put in recently and there are many issues we have found that the pool company is saying is not an issue. I could really use some help to know if I am making a big deal out of nothing.
I have attached pictures.
1) All 4 corners of the liner have a gap. They tried to fix it by putting in these ugly plastic pieces but there is still a gap for plenty of water to enter.
2) The liner around the stairs is very loose and the corners are all wrinkled. I took a picture of one of the stair corners.
3) There is at least 2 spots in the shallow end where you can feel a rock poking up from the liner bottom.
4) On one of the walls you can see the hollow frame of the pool behind it. This is causing a visible line that goes down the liner. Picture is attached for this.
I would appreciate any guidance from you experts. I personally feel they need to empty the pool and redo the liner completely. It's almost time to close the pool for winter so I am getting very worried.
Thanks!
Thanks!
