- Oct 25, 2020
- 106
- Plaster
- Pentair Intellichlor IC-30
Hello everyone -
I have a 14,000 gallon mini-pebble plaster pool and after 30+ days since we added our water, the contractor turned on the SWG yesterday. I had been doing great with my chemistry using liquid chlorine and now everything is out of whack and I have a few questions. I want to see what the experts here think vs. what my contractor is telling me.
Prior to them adding salt, my chemistry was this:
FC - 4-6ppm
pH - 7.5
TA - 110 (started at 140 and I kept lowering pH to 7.2 with acid and using aeration to bring it down)
CH - 350
CYA - 50
Yesterday, they added 9, 40lb bags of salt and one gallon of 14% muriatic acid and turned on the iChlor 30. I watched them do this and they left the salt in the deep end for a while. They eventually brushed it around but it had been there for hours. After leaving, they left the iChlor at 62% and I tested all my levels this morning. Here's this morning's reading:
FC - 1.0
pH - 6.9
TA - 70 (lowest I've ever seen it)
CH - 325
CYA - 50
Salt - 5,000ppm according to Taylor drop test (iChlor 30 reads 4,637) - the cell is blinking green indicating too much salt
CSI - (-0.88)
The iChlor manual says 3,600ppm is ideal and anything over 4,500 is too high. Clearly, I'm too high and they added too much salt.
The contractor has mentioned several things after I've told them what's happening and I just want to get a gut check. Here are the claims they've made:
- Mostly likely, the salt is concentrated in the deep end and run the pump for 24 hours. We will check levels again on Monday
- We added extra bags because the generator needs to convert the salt to Chlorine. It might take a few weeks of use to bring it down (that seems like B.S.) - They added, there should be no damage to the equipment
- If I'm worried about it, they recommended backwashing a foot or so of water and filling the pool back up (I don't have any D.E. on hand, but I can go get some if TFP thinks this is the best course of action)
- Lastly, they recommended putting the cell at 100% for the time being and testing again tomorrow. They also recommended getting the pH to 7-7.2 to make the salt cell work more effectively.
Would love to get thoughts here. Thanks, all.
FC - 4-6ppm
pH - 7.5
CH - 350
CYA - 50
FC - 1.0
pH - 6.9
CH - 325
CYA - 50
CSI - (-0.88)
