@Brentr - Thanks for all the suggestions. I actually have read your build thread before, when we first started planning our pool! Thats where I came up with the idea to go with a smaller pool, larger deck. I thought it would look terrific in our "courtyard" area, with lots of lounge space and entertaining areas. I had planned for these large flat sectional seating areas similar to what we found at Restoration Hardware, and a dining area, outdoor kitchen, and several low chaise lounges, also similar to the RH display we fell in love with.
Long story short - I lost that battle.
My wife has made the command decision to go with the size pool we originally spec'd out. I don't have to pay for it, so I can't complain. We have more yard space to expand the deck if we need more, so there is that. We are not getting a screen enclosure, most likely never will, but if we do then adding the footers is very easy, as we only need them along one edge, right near the road, so easy to pour later and saves me $1500 or so now. We already had several hose bibs installed on both sides of the pool area, and I am planning some added electrical outlets beyond what we already had the builder install. Equipment pad is a very large space, already going to have a gas heater for the spa. There will be room for solar too if we decide to add that. It is lit too. Not sure I will be able to manage the TV positioning, there just isn't a good spot for that, but its a good suggestion!
Oh, and I dont want to give up space on the sun shelf, that was my only win! I think we are going to use that a lot and the dogs will too.
