New Pool in VA, got the first quote
willi3ja
9
VA
Ok so I got a more detailed quote if we could get a second or third set of eyes on it please I deleted the original post in its entirety.
Imagine Inspiration 35’
Filtration
- 1 surface skimmer
- 2 Graeme Baker approved main drain sump pumps
- 3 wall type return inlets
- all plumbing to be glue weld pressure type solid or flex schedule 40
Equipment
- 4x8’ concrete pad
- Hayward vs super pump
- s244 24” sand filter with 300lbs media and 1.5” multi port valve
- Hayward 25k swg
- Hayward summit xl heatpump
Those are kind of the nuts and bolts on the pool side. We’re doing pavers for the decking and a couple retaining walls and an aluminum fence.
Seem reasonable?
Welcome to TFP.
-Skimmer, returns, drains - who many of each?
-LED light - how many? What model?
-Pentair Superflo VS pump - What model number?
-Triton sand filter - Model number? size?
-4x4x4x8 cantilevered concrete decking
-Salt chlorine generator - What model number? SWG should be at least 2X your pool volume.
-S-200 robotic cleaner - ok
-“Upgraded” safety mesh cover - what manufacturer cover?
Pentair Globrites have poor reliability and fit in a proprietary niche. Look into nicheless lights like the MicroBrites...
Filtration
- 1 surface skimmer
Equipment
- 4x8’ concrete pad
- Hayward 25k swg
Seem reasonable?
Just bumping since we got a quote we like better and I’ve included more details as well as deleting the text of the origi post. thanks
What are the dimensions and gallons of your pool? I’m thinking it’s fiberglass?
I haven’t been able to find the gallons, it’s a 16x35 fiberglass. I’m guessing like 17k? It’s a free form shape with a decent size ledge. The rectanglar calculation for that size/depth is 21k but with the curved edges and that ledge 17 is best guess.
thanks
That will be a very nice backyard. Congrats on your pool arriving! Will the pavilion be done at the same time as the rest of the build?
Reactions: bmoreswim
Will,
Congrats on the new pool. Part of the reason you're not getting responses on the equipment is the details matter. Please get the model numbers requested in post #2. It appears your swg may be undersized. TFP recommends sizing for 2x your volume. If you can get the model number we can tell for certain. If the builder will not give you the model numbers that's not a good indication.
Chris
Will,
Chris
I got the actual volume number of the pool and it’s 12,260, so seems like a 25k swg should be fine
That's correct if the swg is truly capable of 25K. I still recommend you get the model number. Trust but verify is a good policy when dealing with any constructor until you know him very, very well.
I hope this is helpful.
Chris
That's all looking really nice! Great timing for swim season. Will you be managing the water yourself? If so, have you bought your test kit?
