Our new 25K gallon gunite pool is filled with water and startup was yesterday. See my build thread in my signature if you‘re curious.
I have an inline chlorinator in addition to a SWG. With a Pebblesheen surface, I can’t add salt for 30 days, so I’m going to rely on tablets / liquid chlorine in the meantime. The builder added trichlor tablets to the feeder yesterday, and I added a gallon of 10% liquid chlorine for a jump start. We also added muriatic acid, liquid stabilizer, and calcium chloride yesterday.
Using my TF-100 kit, I had the readings below this morning:
FC: 3
CC: 0
pH: 7.4
TA: 170
CH: 150
CYA: 30
CSI: -0.23
Doesn’t look too bad, although I need to lower the TA and raise the CH. The CH is easy to add and I have the right amount on hand. To lower the TA into the right range, I need to add 4 gallons of 31% muriatic acid, per Pool Math. My plan is to add enough acid to drop the pH to 7.0, using Pool Math, then let it rise naturally with the plaster curing and turning on the waterfalls.
Any feedback on my numbers or approach would be appreciated. Thanks!
FC: 3
CC: 0
pH: 7.4
TA: 170
CH: 150
CYA: 30
CSI: -0.23
