Despite my trepidations, we have entered contract on a new pool build here in Leander, TX. Never owned a pool before, but wife really wanted one. So here we are. Current rough estimate is to start in September after HOA and city permits are done. Expected to be 4-5 months after that before completion.
I'll try to keep this updated as we work through the process. I'm hoping it will be relatively smooth, I chose this builder because it's the same one that has done all the pools on my street, (4 currently, it's a new street) and all had good experiences.
I expect and am prepared for delays due to shortages in materials and sub contractors. Hopefully they won't be too bad.
General Specifications
Pool Dimensions: 16'8" x 35'6"
Pool Perimeter: 95 ft
Pool Surface Area: 513 sqft
Pool Depth: 3.5ft x 4.75ft x 6ft
Spa Dimensions: 8 ft Circle
Spa Perimeter: 26 ft
Spa Surface Area: 51 ft
Spa Raised: 18 inches from deck.
Spa Depth: 3.5ft
Total Gallons: 18,156 (adjusted for tan shelf)
Plumbing
Pool Pipes: Upto 3 inch Schedule 40 PVC.
Returns: (6) Directional flush mount inlets, placed for maximum efficiency.
Skimmers: (2) Aquastar Skimmer, Indepenendently plumbed for optimum control.
Drains: (1) MDX debris removal drain, (5) 10 inch SDX, VGB compliant. - w/ Paramount Leaf Canister.
Spa Pipes: 3 inch Suction, 2 1/2 inch Return Schedule 40 PVC
Spa Jets: (6) Deluxe Therapy Jets
Spa Air: 1.5 inch dedicated air line.
Spa Drain: Aquastar Circle Drain, flush mount finish, VGB compliant
Fill Line: N/A
Overflow Line: included
Cleaner Line: (1) Independently plumbed
Materials
Pool Shell: 1/2 inch Steel Rebar on 10 inch Centers, both ways.
Pool Bond Beam: 1/2 inch Steel Rebar X 4
Concrete: Dry Mix Gunite rated to exceed APSP Building Standards
Thickness: 12" Bond Beam, 8-10" Walls/Floor All elevated/exposed walls to be 12"
Pool/Spa Tile: 6" Band at waterline, Frost-proof - Std Selection
Pool Coping: Lueder Coping
Spa Coping: Lueder Coping
Spa Facing: Custom Material
Raised Beam: 15 sqft, faced with Custom Material
Equipment
Primary Pump: Pentair IntelliFlo VSF
Feature Pump #1: Pentair IntelliFlo I2
Filter: Pentair Clean & Clear 420 Cartridge
Heater/Chiller: Pentair MasterTemp 400k - NG
Air: Blower - Jandy 1.5HP
Cleaner: Paramount PV3 w/ MDX & Leaf Canister (25 heads)
Control Box: Pentair EasyTouch PS-8
Remotes: Screen Logic Bundle (adapter & wireless kit)
Sanitizers: In-Line Chlor w/ Ultra UV Sys
Additional Actuators: 1 additional 2 actuators included with automation
Pool Lights: (3) Pentair GloBrite LED 12v - Pool
Spa Lights: (1) Pentair GloBrite LED 12v - Spa
Poured/Precast Pad: Delayed Equipment Set W/ Precast Pad
Features
Deck Jets: (3) independently valved for control.
Bubbler - 1 Nozzle: (1) Control valve included.
Spa Spillway: (1) Stone or Tile Spillways.
Spa Depth: 3.5ft
Plumbing
Fill Line: N/A
Materials
Equipment
Features
