- Sep 29, 2020
- 35
- Plaster
- Pentair Intellichlor IC-40
Hi All,
We plan to start excavation next week. We're reviewing the builder proposed equipment list below, while reading the very helpful threads here on TFP.
Pool will be 34' x 17' rectangle with 9' x 7' spa on the side. Two 12" sheers and a bubbler on the sun ledge. SWCG and Dolphin robot added after reading TFP, ozone generator will likely be removed.
Just read a thread related to the Pentair IC40 SWCG that mentioned actuators. Do we need to add those? Do we still need the Automatic In-Line Chlorine/Bromine Feeder?
Is there anything obviously missing, or maybe good to consider? Thanks very much in advance! Happy holidays
Pentair IntelliFlo VSF Pool Pump 011056
Pentair PA220GF 2 Pole Circuit Breaker, 20A - Intelliflo (qty 2)
CMP - Union Threaded 2" MPT x 2" Slip for IntelliFlo & WhisperFlo (qty 2)
Pentair Clean and Clear Plus 420 Cartridge Filter 160301
Trade Grade Pentair MasterTemp 400,000 BTU Heater 460736
Pentair 601012 IntelliBrite 5g Color LED Pool Light - 100 Foot Cord - 12 Volt (qty 2)
Pentair 640132 IntelliBrite 5g Color LED Spa Light - 100 Foot Cord - 12 Volt
Hayward SP0600U DuraNiche PVC Large Lighting Niche; 3/4 - 1 Inch Socket; 45 Deg; Top or Rear Mount (qty 2)
Pentair - 79206600 Small Plastic Niche for Concrete Installation
Pentair 619963 300 Watt Transformer
Pentair - 619962 100 Watt Transformer; 12 -14 V
Pentair - ScreenLogic 522104 Interface for mobile digital devices
Pentair Automatic Water Filler T40FB - Fluidmaster Valve - Almond
Silencer 1.5 HP 240V Air Blower - 6315241
Super-Pro 23301-000-000 Hydrotherapy Jet Body (qty 7)
Super-Pro 25575-509-000 Water Stop Adaptor, Clear (qty 14)
CMP - Eyeball, 1in. Opening, Gray (qty 12)
AquaStar 10AVR103 10 (qty 4)
Paramount 004-202-2230-08 Superflow 360 Degree Color Match Drain; 384 gpm, Light Gray
Pentair - Rainbow 320 Automatic In-Line Chlorine/Bromine Feeder
Paramount Clear O3 Ozone Generator, 120/240V
CMP 25577-131-000 Natural Wonders Waterfall 12 (qty 2)
Pentair - 263026 Three-way Diverter Valve with 2" CPVC Pipe (qty 4)
Pentair - 263027 Two-Way Diverter Valve CPVC 2" - 2-1/2" outside slip (qty 2)
Pentair - 263042 Check Valve with 2" CPVC Pipe - Straight 2-1/2" Slip Outside
Super-Pro SP0801-20H2 Corrosion Resistant Check Valve
TradeGrade Pentair 1.5HP ALMOND SUPERFLO VST VARIABLE SPEED PUMP
CMP 25503-001-000 Bubbler For Natural Wonders Pool Fountains, Gray
Pentair - 520545 EasyTouch 8 Function Control Pool/Spa Combo with IC40
Pentair - 520588 IntelliChlor
Pentair - IntelliChlor Acid Washing Kit
MAYTRONICS Dolphin S200 Robotic Cleaner
Waterway Renegade Venturi IG Skimmer - Gray With Beige Lid (qty 2)
Waterway - 540-6707 Volleyball / Umbrella Pole 1.5
