Hi, we just moved into our new house this weekend and uncovered the gunite pool. 2 months ago we had it inspected and they noted a pH of 7.5 and Cl of 10 and apparently that's all they tested. Today, with a TF-100 kit, I got:
7.5 pH
1.5 FC
0.5 CC
300-325 CH
110 TA
>100 CYA (~1/8" over)
We are on well water that has "some" iron that I still need to test. The house has a water softening system, would need to check if it goes to the outside faucets. What are my options of using the pool this year? Hire someone to drain and bring water if that's even an option? Test my water and hopefully fill in a couple weeks, possibly needing some other kind of filtration? Can I just drain it the pool into the yard/field with a submersible pump? What would potential costs be? It could use an acid washing, and the pool company that did the inspection said it would be about $700 I think, so depending on other costs and if that includes dealing with the water, that might be an ok option.
What should I do about chlorine in the meantime, try to keep it up around 12? Just abandon it and put the safety cover back on until it's dealt with? It's a disappointing discovery when hoping to use it next week.
7.5 pH
1.5 FC
0.5 CC
300-325 CH
110 TA
