Our pool company has cut us free after a three hour pool school and a mountain of documentation. I've been checking out this site and knew that the single Hach strip pack they provided wasn't going to cut it, and I got a TP-100 XL and started off Silver Sponsoring. The pool company hands over the pool with a Pool Frog Leap system with a chlorine pack (chlorine tablets) and an anti-bac mineral pack running (Silver Chloride). I've read that I should switch over to a salt water chlorine generator and ditch the Frog, but we have what we have for the moment.
5 days ago, I received these results (and I turned down the chlorine earlier because it was even higher):
I got these results yesterday, and the pool looks clean and clear for now:
Pool Math Says:
Pool Math Says:
- FC: Add 62 oz by volume
- pH: Add 52 oz by weight of 20 Mule Borax or 26 oz by weight of Soda Ash / Washing Soda
- TA: reduce pH to 7.0-7.2 with acid and then aerate to increase pH
- CH: Add 400 oz by weight
- CYA: Add 40 oz of Dry Stabilizer by weight or 104 oz of Liquid Stabilizer by volume
- Alkalinity Plus (Sodium Hydrogen Carbonate) 5 lbs x2
- pH Plus (Sodium Carbonate) 5 lbs
- Algaecide 60 (Poly(dimethylimino) ethylene-(dimethylimio) ethylene dichloride 40%) quart
- Phos Free 67 oz
- Scum-X 32 oz
- Metal Out quart
- Vertex Pool Shock gallon x4
- Muriatic Acid (32% HCL) gallon
- Additional Chlorine Frog Packs x2
