New pool–Filled April 10th
2 SLOW
41
Cypress, TX
Pool school is Friday but I've been testing the water and it seems out of whack so today is my first attempt to adjust it. I think PB has just been adding pucks to the chlorinator for now and adding some MA here and there:
This morning:
FC--.5
CYA-20
TA-100
Ph--7.8
CH--225
I added 3 cups of 31.45% MA, and 1 gallon of bleach. Will test again this evening and re-do CYA test just to make sure it is accurate. If CYA is still at 20 I'll buy the nylon sock and add some stabilizer (I think there might be a couple trichlor pucks int he chlorinator)
Morning edit: Tested just the FC before I ran out the door this morning and it is at 1.5. Testing again when I get home from work.
jblizzle
43,238
What is your long-term plan for maintaining chlorine levels? Are you going to try to continue to use trichlor tablets in the feeder? Or switch 2 using liquid chlorine?
How big is your pool? I don't see your signature on my phone if you have one.
jblizzle
43,238
Since you are just starting out and your CYA is low, you could continue to use the Trichlor to raise it and the FC levels. They are also acidic so will help keep the pH inline as the pool cures.
Just keep track of how many pucks you use and use PoolMath to tell you how much CYA they are adding.
Once you hit about 50ppm of CYA, you need to stop using the pucks and switch to the bleach.
All the while, using bleach to supplement the pucks to make sure the FC levels are appropriate.
2 SLOW
41
Cypress, TX
Thank you, sounds like I can stick with the trichlor pucks for a few more weeks until my CYA gets up the that level (and adding bleach as needed for good FC level). Once CYA hits 50 ppm and I'm just supplementing with bleach and MA to stay in my FC and PH targets, the CYA shouldn't really change much, correct?
jblizzle
43,238
Correct. The CYA should be fairly constant, although there is some degradation in the intense sunlight it seems. Maybe 5-10ppm loss in a month.
Don't wait for your CYA test to show 50ppm. Calculate how many pucks you have added and how many more you can add until you hit the 45-50ppm mark.
2 SLOW
41
Cypress, TX
Sounds good, thank you for your help!
2 SLOW
41
Cypress, TX
Just wanted to update now that I'm starting to get used to the process and see if most of this sounds correct. In the evenings I've been adding about a half gallon of bleach on a regular day and a gallon of bleach on a swim day. And 2-4 cups of MA.
Current reading this evening after a swim:
FC--2.5
CYA-50
TA-90
Ph--7.8
CH--200
Added a cup of MA and I'm waiting a bit to add the gallon of bleach. Just seems like a lot of bleach everyday. Pool is in direct sunlight with no shade.
mknauss
43,687
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
What % sodium hypochlorite is the bleach that you are using?
mknauss
43,687
Laughlin, NV
Fiberglass
So a half gallon is 1.5 ppm FC. You need to add 3 ppm FC worth every day. Test and see if that holds your FC levels in the target range.
2 SLOW
41
Cypress, TX
It does, I’ve never had to use more than a gallon in the evening. and when I do the overnight test I lose .5-1.
mknauss
43,687
Laughlin, NV
Fiberglass
OK -- so use a gallon each evening. That is 3ppm FC.
Try to find a source of 10% bleach if possible.
Reactions: 2 SLOW
